Activity › Forums › Apple Final Cut Pro Legacy › sync loss when editing rendered clips
  • sync loss when editing rendered clips
    Posted by Roncow on April 27, 2007 at 3:26 pm
    when I am working with rendered clips in my timeline, they lose sync after an edit point…?
    Also… is it not possible to copy rendered clips from one sequence to another?
    Ron
    Roncow replied 19 years, 5 months ago 2 Members · 4 Replies
  • David Bogie
    April 27, 2007 at 5:38 pm
    > when I am working with rendered clips in my timeline, they lose sync after an edit point…?< That's a tough one but it's got to be a user error of some kind. I cannot even imagine where to start looking. > Also… is it not possible to copy rendered clips from one sequence to another?< Only if you import the rendered media. The clip won't actually be rendered in the other sequence until it gets rendered. bogiesan This is my standard sigfile so do not take it personally: “For crying out loud, read the freakin’ manual.”
  • Roncow
    April 27, 2007 at 5:48 pm
    this could be a related issue; occaisionally I’ll find the ‘ghost’ of a render in my timeline.
    In the middle of a clip, an effect rendered clip will appear that used to be at that place in the timeline and has since been moved.
    I workaroud by re-editing the disrupted clip back in (on another level) but this should have some type of more painless resolution.
  • David Bogie
    April 28, 2007 at 1:19 am
    > but this should have some type of more painless resolution. < I'm afraid there is no painless resolution. The only workaround is to fix it from happening in the first place. None of these symptoms should be happening at all. First place to look is where are you storing your media files? bogiesan This is my standard sigfile so do not take it personally: “For crying out loud, read the freakin’ manual.”
  • Roncow
    April 28, 2007 at 2:56 am
    my files are on one of two FW400 drives…
    But– this is a project I just upgraded from 5.01 to 5.1, so…
    That might be a contributing factor…?
    macbook pro 2.16ghz
    2GB RAM
    FCP 5.1
