Activity Forums Apple Final Cut Pro Legacy sync issues w/ HD to Quicktime .mov
  • sync issues w/ HD to Quicktime .mov
    Posted by Chris Gallaway on February 27, 2008 at 4:19 pm
    Hi there,
    I’m editing a short piece on an HD timeline in FCP 5. When I attempt to export the piece using Quicktime conversion for upload to the web, the audio sync gets messed up. In the exported .mov, it appears that the sound plays smoothly, but the video keeps jumping around, skipping, and falling out of sync with the sound. I’ve tried exporting in both HD and SD dimensions.
    I’m using H.264 and Little Endian, and I’ve checked to make sure the frame rate is set correctly. Any thoughts on why this could be happening. Am I merely over-taxing my CPU and causing the computer to bog down? I’d much appreciate some help with this,
    Chris G.
    Chris Gallaway replied 18 years, 5 months ago 2 Members · 2 Replies
  • Del Chapple
    February 27, 2008 at 4:39 pm
    you maybe taxing the cpu..?? pcm audio is alot easier to decode than h.264 and may explain why the audio is file yet the video is having problems. try h.264 with aac audio, that ways its all mpeg. and try 2 different uncompressed codecs like Animation for video and Pcm audio.. a little rnd never hurts..
    del
    you cant hear my inner voice scream… can you..?
  • Chris Gallaway
    February 27, 2008 at 5:06 pm
    ‘Preciate it, Del. I’ll give those things a shot.
    -cg
