Activity › Forums › Apple Final Cut Pro Legacy › Sync Issue (Urgent)
  • Sync Issue (Urgent)
    Posted by Bryant Francis on December 11, 2010 at 1:10 am
    Hey all, got a real problem down here. I’m working on a short fiction film, and something’s gone screwy as hell with my workflow. Long and the short of it–after my audio came back from the Mixer, it no longer syncs with the original image…in ANY sequence, either the new color corrected sequence or the original “picture lock” sequence. Here’s what’s happened.
    First off, we shot 1080p at 30p.
    1. I received the audio, attempted to sync it up with the footage. Despite my best attempts, it would not sync completely. If it synced in the beginning, the audio lagged towards the end. If it synced in the end, it would not sync in the beginning! (Did not test if it lagged or was in advance). At first thought it had to do with something we did in Protools, have since 100% ruled that factor out.
    2. After trying in multiple timelines, I desperately went to DVD studio pro with the Quicktime file I gave to my sound mixer, and the afi file I had now. To my surprise, they sycned up in DVD studio pro! The quicktime made 3 weeks ago and my audio worked together. (This is also my backup plan for going forward with this project.)
    3. After more tests, including taking that quicktime back into final cut pro, I have concluded something’s changed accidentally in the general settings. Every sequence has the exact same sync problem, regardless of other visual modifications.
    The problem is, I don’t know what to look for to get my sequences back up to speed in Final Cut Pro. If anyone has any advice, I’d sincerely appreciate it..
    Michael Gissing replied 15 years, 9 months ago 2 Members · 1 Reply
  • Michael Gissing
    December 11, 2010 at 2:47 am
    Audio sync is one of the most common threads here. FCP does a really dumb thing and stamps a frame rate on imported audio based on your default project settings, not current open sequence. Why? Ask Apple.
    Read this tutorial as it gives explicit instructions on importing audio so the settings match the correct frame and timecode rate of your sequence.
    https://library.creativecow.net/lyon_matt/fixing-fcp-assets/1
    The other thing to always ensure is that your sample rate is 48khz (clip and sequence settings) and the bit rate is either 16 or 24 bit. No mp3 or aac compression, just aif or wav files.
