Activity Forums Adobe Premiere Pro Sync issue
  • Sync issue
    Posted by Roger Matthews on May 24, 2014 at 3:19 am
    Hi, I’m syncing three sources of media together – 2 5D cameras at 23.976, and 1 external audio source (48khz 24bit uncompressed at 29.97)
    The cameras sync together just fine, but the external audio seems like the framerate difference (29.97 vs 23.976) is causing it to drift/slide out of place.
    However, the ‘Interpret Footage” command seems to only work for video clips, and not audio. I’m used to AVID, where when you bring in audio, you just specify the necessary framerate. Most PPro users I’ve talked to have never changed framerate for audio, they say, and aren’t sure of what to do.
    I’m sure this is a basic situation, but I can’t find any answers so far! Many thanks for any help.
    Roger Matthews replied 12 years, 4 months ago 1 Member · 0 Replies
  • 0 Replies
