Activity Forums Broadcasting Sync image settings between two camers?
  • Sync image settings between two camers?
    Posted by Martin Nilsson on September 19, 2012 at 8:50 am
    Hi, I’m a newbie here trying to research how to synchronize the image appearance from two different cameras.
    Say I have two live cameras of different brands in two different scenes (or in the same scene), what is the procedure for making the video feed from the cameras look the same, i.e same white balance, saturation, brightness, gamma, etc, so that I can seamlessly cut between them?
    Is this a problem in broadcasting and if so, how is it done? Is it all manual tweaking on each camera or do all cameras have some standardized settings?
    /Martin
    Tom Matthies replied 13 years, 9 months ago 2 Members · 3 Replies
  • Tom Matthies
    September 27, 2012 at 1:44 pm
    What cameras are you using? What switcher?
    E=MC2+/-2db
  • Martin Nilsson
    September 27, 2012 at 2:59 pm
    I’m not using anything at the moment. This is a theoretical question for a research project. I’m wondering if there is a problem here that needs to be solve, or if there already is a solution for this problem.
    /Martin
  • Tom Matthies
    October 24, 2012 at 2:44 pm
    If the cameras are not broadcast units with a reference (Genlock) input, you will need to use a switcher with build-in frame syncs on the inputs. This will eliminate the need for synchronizing your cameras. As for matching, some switcher will offer a Processing Amp feature to match the cameras. Otherwise, you will need to spend some time matching the cameras through the controls on the cameras. Use the same white balance reference under the same lighting conditions for a start. The rest is tweaking the cameras until they match as well as possible.
    E=MC2+/-2db
