Activity › Forums › Adobe Premiere Pro › Sync generator question
  • Sync generator question
    Posted by Brad Bussé on January 22, 2018 at 4:38 pm
    I’m looking at replacing an audio interface for use with DAWs. Some of the one’s I’m looking at only have LTC Output. For when I’m working in Premiere, can I sync that interface with my Blackmagic video interface by using the LTC Output of the audio interface as the sync generator out to the Blackmagic, and just bypass the need for a dedicated sync generator?
    Brad Bussé replied 8 years, 8 months ago 2 Members · 2 Replies
  • Brent Marginet
    January 22, 2018 at 7:43 pm
    The only time you really need to use sync is when you are doing outputs to tape.
    Sending T/C from the Audio Interface to the BM Card will do nothing at all.
    \”MY MEDIA/PROJECT MOTTO: If you think three copies of your Media or Projects are enough. Take a moment to place a value on them and then maybe add two more.
    Hard Drives are now stupidly cheap. A RE-SHOOT AND YOUR TIME AREN\’T.\”
  • Brad Bussé
    January 22, 2018 at 8:24 pm
    So I can reliably keep monitoring output sync between separate video and audio interfaces by timing internally?
