Activity › Forums › Adobe After Effects › Sync Flare with 3D null object
  • Sync Flare with 3D null object
    Posted by Fabricio Micheli on December 6, 2010 at 11:28 pm
    Hi guys, Im using AE and I have a null object (where my camera look at), and I want to add a Flare to that point. What I did is to add a new solid, applied a flare, and using screen mode to blend the layer, it transfers really good to the comp, but! I cannot sync the flare position (2D) with the null object…
    is there a simple way to do it?
    I thougt about using some tracking but i dont know if it will work fine.
    Any advices will be really appreciated!
    Fabricio Micheli replied 15 years, 10 months ago 2 Members · 4 Replies
  • Andy George
    December 6, 2010 at 11:47 pm
    You can tie them together with an expression.
    Name your null object “Flare_Source”, make sure 3D is enabled for it.
    Now after you apply the flare effect to a new layer, Add this expression to the flare center attribute:
    thisComp.layer(“Flare_Source”).toComp([0,0,0]);
    -Andy George
    Senior Editor
    http://www.chiselindustries.com
  • Fabricio Micheli
    December 7, 2010 at 1:28 am
    Hi Andy, thanks for the reply!
    Im trying to tie both objects but I got an error message:
    “Unterminated string constrant Expression disabled.”
    The software disables the link… is it right the expression or maybe Im doing something wrong…
  • Andy George
    December 7, 2010 at 3:09 am
    Seems to be working for me and im not Java savey enough to determine what the error is referring to.
    Here is an after effects project file where I linked a null to the flare using the expression. It’s created in CS4 that should open in CS4 or or CS5.
    https://www.chiselindustries.com/Client/lenseflare.aep
    -Andy George
    Senior Editor
  • Fabricio Micheli
    December 7, 2010 at 4:00 am
    Thanks man! it works pretty fine! Ive found the error. Thanks a lot for your help man.
    Cheers!!!
