Activity › Forums › Adobe Premiere Pro › Sync Edit Function
  • Sync Edit Function
    Posted by Grayson Sedory on January 5, 2015 at 6:10 pm
    I am curious to see if there a sync edit function similar to other edit systems i have used.
    Scenario:
    Say I have a baseball hit with no audio in my timeline.
    I also have some clean audio of a baseball hit and I would like to sync up the audio of the baseball hit in my source to the exact frame that the ball makes contact in the timeline.
    Is there a one button feature where I can set my playhead on the frame of bat contact in my timeline and the bat crack frame in my source audio so that they will automatically sync and fill in within the timeline around the playhead?
    Please let me know if this makes sense. I am using CS6.
    Grayson Sedory replied 11 years, 8 months ago 4 Members · 9 Replies
  • 9 Replies
  • Tero Ahlfors
    January 5, 2015 at 6:18 pm
    I’ve used iQ a bunch so I do know what you’re talking about. It’s a pretty neat thing but AFAIK it’s not available in Premiere.
  • Grayson Sedory
    January 5, 2015 at 6:24 pm
    Ok yea I work primarily with Quantel and that feature is great. A lot of the shortcuts are labeled differently in premiere and I wanted to see if I was missing something.
  • Tero Ahlfors
    January 5, 2015 at 8:32 pm
    I’ll try to explain this to the folks that probably still don’t know what we’re talking about.
    Let’s say I’m making a tough online edit and I need to manually edit and sync some shots in. The best sync point I find in the timeline clip is in the middle of it and then I’ll search the same frame in the source clip. Then when I make the sync edit the edit goes from the playhead (that’s parked in the center of the clip) to both directions stopping at the clip’s in and out point “filling” the clip with the source footage.
  • John Pale
    January 5, 2015 at 9:23 pm
    Does this do what you want?
    Position the playhead in the source monitor.
    Position the playhead in the Timeline.
    Select the clip in the Timeline.
    Go to Clip>Replace With Clip>From Source Monitor, Match Frame
  • Morten
    January 5, 2015 at 9:41 pm
    Or just press M on each clip to set a Marker. Then align by snapping markers together in sequence…
    – No Parking Production –
    Adobe CC2014, 3 x MacPro, 3 x MbP, Ethernet File Server w. Areca ThunderRaid 8
  • Tero Ahlfors
    January 5, 2015 at 10:02 pm
    [John Pale] “Clip>Replace With Clip>From Source Monitor, Match Frame”
    This is pretty much it. I must’ve missed some release notes.
  • John Pale
    January 6, 2015 at 1:28 am
    I’m actually fairly new to Premiere Pro. I just did it in a tutorial recently.
  • Grayson Sedory
    January 6, 2015 at 1:37 am
    Thanks for the replies, I will try that out when i’m back at work tomorrow!
  • Grayson Sedory
    January 12, 2015 at 3:26 pm
    That sounds like it would work but what if I am selecting a blank area on the timeline to replace with my audio? The Replace With Clip option is greyed out if that is the case. Is there any way around that?
