Activity Forums Apple Final Cut Pro Legacy sync drift, pulldown, FCP and 16mm telecine
  • sync drift, pulldown, FCP and 16mm telecine
    Posted by Renee Litapop on October 30, 2010 at 4:31 pm
    i’m working in FCP on a project that combines XDCAM and 16mm material.
    i just got back my first two rolls of 16mm telecined to ProRes from the lab. the telecine framerate seems to be 23.98. The sync is drifting badly when i try to sync up the roll of film (it’s one lone 11 minute 400 foot take). I presume this is because the film is now 23.98 instead of 24fps? So what am I supposed to do to fix this? Did the lab do something wrong? They didn’t ask me anything about framerate and what I wanted, but I assumed they knew the standard way of doing this. Or is there something I am supposed to do to change the playback rate of the audio to match? What exactly should I do and how?
    Also, will it be a big problem later down the line to combine this material with 30P material in one timeline?
    Please help and advise — this is a new workflow for me, and I am not sure how to set this up so that things run in sync. thanks!
    David Roth weiss replied 15 years, 11 months ago 2 Members · 1 Reply
  • David Roth weiss
    October 30, 2010 at 4:50 pm
    Your picture is probably not the issue, it’s the audio. Sound Track Pro has an excellent set of features for adding pull up/pull down that’s super easy. I’d suggest that you read the manual and then try it out.
    Mixing 23.98 and 30 is a whole different can of worms. Get your audio and video in sync first, then come back.
    David Roth Weiss
    Director/Editor/Colorist
    David Weiss Productions, Inc.
    Los Angeles
    http://www.drwfilms.com
    A forum host of Creative COW’s Business & Marketing and Apple Final Cut Pro forums. Formerly host of the Apple Final Cut Basics, Indie Film & Documentary, and Film History & Appreciations forums.
