Activity Forums VEGAS Pro Sync Cursor on Genertaed Media
  • Sync Cursor on Genertaed Media
    Posted by James Wilhelmi on January 31, 2010 at 8:16 pm
    This is probably a simple fix – just can’t find it. Is there a way to sync the cursor on generated media? This box is grayed out but I do have this option in the pan/crop & fx windows.
    James
    Gilles Pialat replied 16 years, 7 months ago 4 Members · 3 Replies
  • John Rofrano
    January 31, 2010 at 10:07 pm
    The sync cursor doesn’t work for Generated Media and we’ve asked Sony for this option many times. Please let your voice be heard and fill out the Sony Product Suggestion form for this feature. Not having this makes syncing with Generated Media nearly impossible.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
  • Joe Mantaratz
    February 1, 2010 at 4:40 am
    But it still can be done you just can’t see the cursor position in the window so you have to add your keyframes and then just drag your timeline cursor to see the changes. You can also drag the cursor in the generated media timeline as well and you will see the changes in the window. Text does not have a sync cursor either but you can keyframe that as well. Not the best or the easiest way but you can do it you just have to spend a little more time getting the timing right.
  • Gilles Pialat
    February 1, 2010 at 6:41 am
    There is a simple workaround to sync cursor of generated media:
    -open the generated media in trimmer
    -copy/paste timecode from trimmer to generated media timeline.
    Here, my French tutorial.
