Activity Forums Adobe Premiere Pro Sync ‘Current Time Indicator’ when dynamic linking between After Effects and Premiere Pro
  • Sync ‘Current Time Indicator’ when dynamic linking between After Effects and Premiere Pro
    Posted by Joep Becking on August 7, 2013 at 7:51 am
    Hi all,
    I have a AE project with a Premier Pro Sequence in it via dynamic linking. I’m curious, is there a way to sync the current time indicator of after effects and premiere pro when working via dynamic linking? This would speed up the process a lot in this workflow.
    Regards,
    Joep
    David Honan replied 11 years, 11 months ago 2 Members · 1 Reply
  • David Honan
    August 15, 2014 at 10:31 am
    Hi Joep,
    I think I know what you mean so here goes (On a mac). Toggle through the timecodes on both after fx and Premiere by holding down the cmd key till both clocks look the same 🙂 Good luck.
    David
