Activity Forums Apple Final Cut Pro Legacy sync audio fcp
  • Posted by Jan Janssen on January 5, 2011 at 1:37 pm
    recently did a registration with multiple camera’s ( all 25 fps) of a concert.
    one layer is 16bit integer at 48,0 khz the other audio is captured in 32 bit floating point. syncing those two is no a problem but this was just captured with a regular mic, because i would get the final mix later
    but when i got the final mix.. and wanting to sync it with the video
    the first 30 seconds are synced fine but then you hear and see that the final mix is about half a second (12 frames) faster… can not get it in sync. maybe this is allready posted somewhere but can not find it.. does someone know how to fix this?
    Jan Janssen replied 15 years, 7 months ago 3 Members · 4 Replies
  • Sam Mallery
    January 5, 2011 at 4:31 pm
    I’m having a similar problem. I just did some searching and found this:
    https://forums.creativecow.net/readpost/8/1098915
    But, as you can see, no one provided a solution. I have a 5 minute project that I edited in FCP and exported and mixed the sound in Ableton Live 8. When I exported the final mix out of Ableton and imported it back into FCP, it’s the same problem. The first 30 secs or so is fine, and then you start to notice a little drift. By the end of the video the drift is really apparent.
    http://www.sam-mallery.com
  • Jan Janssen
    January 5, 2011 at 6:26 pm
    yep I know.. been reading al lot.. seems to be a familar problem.. i will let you know if i find something that worked for me, in the mean while i still hope someone has the answer out there!
  • Michael Gissing
    January 5, 2011 at 10:19 pm
    A couple of things. Files in FCP should only be 16 or 24 bit and 48khz. Firstly make sure that is the case. Also only use PCM, not mp3s or aac.
    There is a known issue in FCP importing files that then drift out of sync. This tutorial answers the question of why this may occur (second half, with instructions on how to best import assets that will not drift),
    https://library.creativecow.net/lyon_matt/fixing-fcp-assets/1
  • Jan Janssen
    January 6, 2011 at 1:58 pm
    micheal and sam thanks for your response, and taking the time to answer
    i’ve checked the xml tutorial but that did not do the job for me. in all my frustration i started playing with the khz and for some reason allthough my camera audio is 48000 and my final mix is also 48000 it seems to work for me that i have changed to 44100 and 16 bit instead of 32 bit and 48000,strange..
    i have no idea why it worked but it did.. thanks
