Activity › Forums › AJA Video Systems › Sync all over the place
  • Sync all over the place
    Posted by Paul Harb on March 22, 2010 at 4:20 pm
    Forgive me as this is my first RED project, so I am still learning this workflow.
    I shot a music video on RED at 4k/ 23.98, and transcoded those R3D files to Apple Pro Res 422HQ 23.98 1080×1920 to edit. For some reason I am having all sorts of sync issues. Its out of sync, I stop it….its back in sync…then goes out again….nothing consistent either…its totally random which is maddening. Its in sync on my output monitor, but out of sync in my timeline, or vice versa….all over the place….Am I doing something wrong here? Anyone else have this issue, Im sure its something Im not doing but I cant figure it out. THks.
    Paul
    Mac Pro 2x 3.2 Quad
    8Gig RAM
    OSX 10.5.8
    FCP 7.0.1
    QT 7.6.4
    Digital Maxx E-Sata RAID
    Paul Harb-Producer/Director
    Wrong Beach Multimedia
    Dual 3.2 GHz Quad/10.5.5/8GIG RAM/FCP 6.0.4/QT 7.5.5
    Gary Adcock replied 16 years, 5 months ago 6 Members · 29 Replies
  • 29 Replies
  • Paul Harb
    March 22, 2010 at 9:44 pm
    Hoping someone else could chime in here, Ive been reading that others have had this issue as well, but those were dated back in 08 soooo….not really current info that I can find. I did notice that my timeline settings were set to 24bit I think, I changed that to 16bit as the track is an AIFF not camera audio. Its a music video.
    Paul
  • Gary Adcock
    March 22, 2010 at 11:25 pm
    [Paul Harb] “Hoping someone else could chime in here, “
    I did not respond because there is so much info missing to answer your question.
    There is NO mention what kind of audio you are using and where did it come from?
    what is your workflow, from camera into FCP
    If you did, which app did you transcode with and which OS version is the camera on?
    gary adcock
    Studio37
    HD & Film Consultation
    Post and Production Workflows for the Digitally Inclined
    Chicago, IL
    https://blogs.creativecow.net/24640
  • Paul Harb
    March 23, 2010 at 12:12 am
    Sorry, I thought I did. The audio is a track NOT from camera, it is an AIFF that is 48k 16bit audio. This is a music video. We shot the RED cams at 4k 23.98…the track was used as playback. I used REDRUSHES to transcode the R3D files to ProRes 422 HQ 23.98 1080×1920.
    Now, this is a random thing. Sometimes its out, Ill stop it play again and then it will go back in sync at the same spot that was just out….so Im not sure how it could be some drift due to frame rate/ audio sample rate even though thats the only thing I can think of unless its something with the Kona..I dont know.
    THks,
    Paul
  • Gary Adcock
    March 23, 2010 at 12:14 pm
    [Paul Harb] ” I thought I did. The audio is a track NOT from camera, it is an AIFF that is 48k 16bit audio. “
    Have you bothered to check to see that FCP wants 48K 24bit audio and that might have something to do with your problem?
    that along with any gaps or empty spaces in your timeline can cause the audio drift you describe-
    it’s a settings problem so try rendering a “mix down” for your audio, that will fix it until you edit the timeline.
    gary adcock
    Studio37
    Chicago, IL
  • Paul Harb
    March 23, 2010 at 4:28 pm
    HEy Gary,
    Whats with all the hostility???? The timeline WAS originally set to 24bit 48k and it was drifting all over the place. Why would gaps in the timeline create a drift randomly that is there one minute and then if I play the same spot again its in sync? I will trying mixing down my the AIFF file to 24bit as you say and see if that makes a difference. This is a new workflow for me, so you might cut me a little slack…or not.
    Paul
  • Mark Spano
    March 23, 2010 at 4:40 pm
    Sounds similar to a problem I had a long time ago with a KONA 3 card. It would start playing with video and audio in sync and slowly drift out. Turned out that the card was not in the correct slot in the Mac Pro. Figure out which cards you have and what slots they belong in – AJA has a primer on their site to tell you where the KONA belongs. It might be in a lower performing slot than necessary and therefore unable to handle the throughput of an HQ sequence.
  • Gary Adcock
    March 23, 2010 at 5:11 pm
    [Paul Harb] “Whats with all the hostility????”
    the hostility started with the “Nobody” response to your own request.
    “This is a new workflow for me, so you might cut me a little slack…or not. “
    The needs for FCP do not change because you choose to not follow them. FCP always wants 48k 24bit audio regardless of where the audio ( and or video) came from.
    the Mixdown I was talking about is a render inside of FCP.
    you are working with audio that is not in spec for real time playback. That means that it needs rendering to playout, gaps in the timeline mean that the render jumps to the next clip to begin rendering whether you have video or not. so the blank areas of your timeline are exacerbating the issue of your audio not being correct.
    gary adcock
    Studio37
    Chicago, IL
  • Paul Harb
    March 23, 2010 at 6:14 pm
    So your mad that I asked if anyone has run into something similar? Maybe you need to take a deep breathe.
    I have always used 48k 16bit audio….not sure Ive ever used 24bit audio….your telling me you always use 24bit audio on your video projects? I have not.
    Paul
  • Paul Harb
    March 23, 2010 at 6:15 pm
    Hey Mark,
    This to me makes more sense than Gary’s 24bit statement. He is saying that my setting are screwed up and I should be using 24bit audio? Im not sure I understand this. Like I said the sync issue is random and fixes itself when I stop and replay the same section, I will call AJA and see if they can help me, thks for the response.
    Paul
  • Walter Biscardi
    March 23, 2010 at 6:18 pm
    [Paul Harb] ”
    I have always used 48k 16bit audio….not sure Ive ever used 24bit audio….your telling me you always use 24bit audio on your video projects? I have not.”
    FCP defaults to 24bit audio. This is what you should be using at all times, as Gary says. In order to run 16bit audio you have to manually change the FCP default.
    Digital audio is 24bit. If you’re running 16bit audio, you can run into the very issues you have described and which Gary has already addressed in his answers.
    Look at any Sequence Preset in FCP. They’re all 24 bit audio for a reason.
    Walter Biscardi, Jr.
    Editor, Colorist, Director, Writer, Consultant, Author, Chef.
    HD Post and Production
    Biscardi Creative Media
    “Foul Water, Fiery Serpent” featuring Sigourney Weaver coming soon.
    Blog Twitter Facebook
Page 1 of 3
