Activity › Forums › Avid Media Composer › Symphony’s Boris
  • Symphony’s Boris
    Posted by Robert Ober on July 3, 2012 at 1:39 am
    Hello Folks,
    I have the Symphony from FCP crossgrade coming. Is the Boris FX version the same as the version one would buy separately? Is it version 8?
    Also, am I correct to understand there is not a separate encoding application with Symphony that does not require a DS?
    Robert
    Robert Ober replied 14 years, 2 months ago 2 Members · 2 Replies
  • Shane Ross
    July 3, 2012 at 3:38 am
    [Robert Ober] “Is the Boris FX version the same as the version one would buy separately? Is it version 8?”
    Yes.
    [Robert Ober] “Also, am I correct to understand there is not a separate encoding application with Symphony that does not require a DS?”
    Normally…no. YOu’d have to buy Sorenson Squeeze separately. But the crossgrade you got also includes that.
    Shane
    Little Frog Post
  • Robert Ober
    July 3, 2012 at 3:44 pm
    Thanks Shane,
    Just finished reading a review that compared Squeeze to Compressor using a ProRes to H.264 encode. Compressor was cleaner but the tester was able to improve the Squeeze encode with a preset (he called it a filter) that is supposed to help web video.
    The reason I asked is that I have Compressor and some others but I not sure I have anything that handles DNXHD but I will look at my Episode 6. Not a fan of the supposedly easier interface Episode uses these days.
    BTW, is it the full or the lite Squeeze?
    Thanks Again,
    Robert:-)
