Activity Forums Avid Media Composer Symphony stuck on Initializing Avid Media Access Volume Manager.
  • Symphony stuck on Initializing Avid Media Access Volume Manager.
    Posted by Frank Raposo on October 16, 2012 at 10:22 am
    I can’t get my Symphony 6.0.3 to open on my iMac running Lion10.7.4 3.4 Intel Core i7 16 GB. It just freezes there until I get a warning that says “Invalid File Name.” I just installed it and it opened but it didn’t see my project. When I tried double clicking on the project, Symphony just got hung up on that portion of the startup. It just hangs there until I get the error message. I’ve tried opening other projects this way and I get the same problem. If I start Symphony by double clicking, I now also get the same problem. I just had it open. I don’t understand why it would open one time and now it won’t.
    I initially had it installed on my Macbook Pro temporarily while my iMac was getting a new video card put in. Since my iMac died before I cold de-authorize, I called Avid and had them do it. I then installed on my Macbook Pro temporarily but I received my iMac back today, de-authorized the Macbook, and re-installed on my iMac. But I don’t know if this has anything to do with my problem but I thought I should mention it. Any help would so greatly be appreciated.
    quinnmcguee
    Nikki Davis replied 11 years, 4 months ago 6 Members · 8 Replies
  • 8 Replies
  • John Pale
    October 16, 2012 at 12:26 pm
    If you are connected to an Ethernet network, disconnect before launching the app.
  • Glenn Sakatch
    October 16, 2012 at 1:23 pm
    do you have an external drive plugged in? If so, unplug it then launch the program.
    Glenn
  • Shane Ross
    October 16, 2012 at 4:48 pm
    What John said. Mine hangs until I turn off my Airport. Then it launches. Then I turn back on my airport.
    Shane
    Little Frog Post
  • Frank Raposo
    October 16, 2012 at 8:01 pm
    Ok, shutting down my external worked. I’m able to start Symphony but now I’m getting an error that says, “Exception: A serious error has occurred! It is recommended that you immediately save your work and restart your system,” which I have.
    quinnmcguee
  • Frank Raposo
    October 16, 2012 at 8:46 pm
    I should note that the media is linked to AMA. Shot on 5D.
    quinnmcguee
  • Frank Raposo
    October 16, 2012 at 8:59 pm
    Ok, I deactivated on my iMac because of the error messages and re-activated Symphony on my Macbook Pro and the project opens and works fine. Very weird. Must be a computer problem? It will be slow going on a Macbook Pro but at this point it’s better than nothing.
    quinnmcguee
  • Tina Hedegaard
    October 20, 2012 at 6:55 pm
    Last time I experienced that issue it was because a client had put a cd in the computer. The cd contsined a / in the name or on the disc.
    Check if you have any drives with some “forbidden” letters on it.
    Cheers
    Tina Hedegaard
    Editor | Assisting Editor
    Final Cut Pro 7 | Media Composer 5.5.3/6.0.1.1
    Mac OS 10.6.8| Mac OS 10.7.4
  • Nikki Davis
    May 21, 2015 at 2:48 pm
    That was it! A cd. Avid reeeally doesn’t like those backslashes, huh?
