Activity Forums Avid Media Composer Symphony Nitris Batch Capture issues
  • Symphony Nitris Batch Capture issues
    Posted by Scott Skaja on August 25, 2006 at 12:50 am
    I am running Symphony Nitris 1.5.3 on an HP8200. I am batch capturing from digibeta show masters with rock solid time code on them. One out of four captures halt with either:
    “Capture aborted due to discontinuity in time code”
    or
    “Failed to find coincidence point on tape”
    I have changed various settings on both Symphony and the deck itself to fix this… same result. I am starting to suspect a bug.
    Anybody else have this experience?, and if so what has been your remedy? I am tired of hitting the “Try Again” option in the capture tool.
    Scott Skaja
    Freelance Editor
    Minneapolis, MN
    Jeff Burford replied 19 years, 11 months ago 4 Members · 3 Replies
  • Geraint Pari huws
    August 25, 2006 at 8:16 am
    Have you tried changing the tc for preroll in your settings to ctl or best…
  • Morten Raarup
    August 25, 2006 at 7:20 pm
    I had a problem like that on my adreanline HD. I was a setting who was corupt. I deleted al avid settings and did a reinstall, then it worked.
    Morten Raarup
    On Off Line Postproduction
    Copenhagen, Denmark
  • Jeff Burford
    September 25, 2006 at 9:38 am
    Great Tip!
    We are having the same exact problems…..
