Symphony 6.5.4 AMA Linked DVCPRO HD MXF
Hello All,
I am trying to resolve an issue where clips that are DVCPRO HD MXF are not playing in the Symphony. DVCPRO .MOV are fine. All other .mxf’s are fine. I have spoken with Avid at length about this. They are trying to figure out a solution or cause. I have sent them various files as well, they are actually about to duplicate the issue on their end which is a good indicator that its not my local system. I just wanted to see if anyone has encountered this issue, advice, or know of a solution i can use.
Here is the error message I get when AMA Linked:
Exception Failed to get the sample rate position from AMA plug-inWhen i Import
Exception: MXFImport XDCAM-Unrecognized resolution.I did have both P2 and XDcam Plug in installed on this synphony.
Thank you in advance.
