Activity Forums Maxon Cinema 4D Symmetry side with Knife tool does not work?
  • Symmetry side with Knife tool does not work?
    Posted by Kale Collins on July 4, 2018 at 5:12 am
    Hi-
    I’m fairly new to modeling and am only just getting started on what I’d like to be a dragon.
    Starting with the head I begin with a single 4 polygon cube, I make it editable and delete half of it with the loop knife tool, Optimize so the points are correct.
    (It’s also under a Null) apply the object under the Symmetry tool, and change the “mirror plane” to XY
    It is mirrored- however when using the Knife Tool (loop) the cuts are not effected on the symmetrical side.
    Is this possible to do without a plugin? what am I missing here…..
    Brian Jones replied 8 years, 1 month ago 2 Members · 3 Replies
  • Brian Jones
    July 4, 2018 at 5:22 am
    What you are describing (or what I think you are describing) works here. Need more info, the scenefile perhaps.
  • Kale Collins
    July 4, 2018 at 3:06 pm
    Here is my file! do let me know if theres any solution ,
    cheers ☺
    12501_example.c4d.zip.zip
  • Brian Jones
    July 4, 2018 at 3:28 pm
    it’s definitely working here, it can’t not work I think, since the symmetry side is a direct copy. You won’t see it unless you select the Symmetry object after the cut or change the display mode from Gouraud Shading to Gouraud Shading (Lines) – or any of the (Lines) modes – or are you meaning something different?
