Symmetry issue C4D
Hi All,
Here is a problem that baffles me.
I’ve created a tube and added symmetry to it. It worked fine and points welded properly and looked good under sub-d.
I realized later on that my topology was wrong so I decided to start over.
The only issue is that the symmetry won’t weld properly with sub-d activated, kinda extending towards the bounding box at the seam level. It seems to only affect tubes, not cubes…
So weird.
Anyone has an idea on this?
Thank you
