Activity Forums Adobe Photoshop Symmetrically/Porportionally duplicate/resize an object to fit in another
  • Symmetrically/Porportionally duplicate/resize an object to fit in another
    Posted by Jeff Krieger on August 15, 2014 at 8:36 pm
    Hi, I have a rectangle. I would like to create a symmetrical border inside that rectangle. Duplicating the layer and scaling it doesn’t work. It’s not proportional. How do you do this?
    Thx.
    Jeff Hinkle replied 12 years, 1 month ago 2 Members · 2 Replies
  • Jeff Krieger
    August 15, 2014 at 9:47 pm
    In Illustrator it’s offset path
  • Jeff Hinkle
    August 15, 2014 at 9:51 pm
    Couple ways:
    If you just need an inside border, apply the Stroke effect set to Inside. adjust color and thickness to taste.
    If you need a separate rectangle, make a selection from your original rectangle, choose Select>Modify>Contract and set the Contract By value to how thick you want the border. You now have a proportional selection from your rectangle.
    It is easier to destroy than to create.
    More fun, too.
