Activity Forums Adobe Premiere Pro Symmetrically change transition duration
  • Symmetrically change transition duration
    Posted by Graham Hutchins on June 6, 2012 at 8:59 pm
    Hello all.
    One more UI quirk that I’m not able to find an answer to in either the forum or the manual.
    I’d like to be able to symmetrically drag the in and out point of a given transition, like a cross-fade or what-have-you, similar to the default behavior in FCP where you can grab one side of a transition and it automatically shortens the other side equally.
    I’ve tried a bunch of different key combos while dragging and I’m still only able to change the length one side at a time, which is definitely a great feature to have, but most of the time, I want my fades to be the same length on either side of the cut.
    I’m aware that I can double click the transition and either drag or key in via the keypad a duration, but that seems slower than it should be and I’d like something a little more precise than adjusting one side and then the other in the timeline.
    Thank you for your time.
    -Graham
    OSX 10.7.4, Windows 7
    Adobe CS6
    FC Studio 3
    DaVinci Resolve
    Octo 2.26GB MacPro, 32 GB RAM
    Bala Chandran replied 14 years, 3 months ago 2 Members · 1 Reply
  • Bala Chandran
    June 7, 2012 at 11:21 pm
    Highlight the transition and in the Effect Controls window drag your mouse over the duration numbers while holding down the left mouse button (win).
