Activity Forums Avid Media Composer SxS Card Footage
  • SxS Card Footage
    Posted by Dan Brother on March 16, 2012 at 5:49 pm
    Hi all. First off, I’m editing on a Mac-based Media Composer, V5.5.2.
    I’m trying to ingest footage that was recorded to SxS cards and can’t get the Avid to recognize it. The info I’ve gathered through Quicktime (which also can’t open them) on the clips is this:
    MPEG-4 Video, 1920X1080, Linear PCM, 16 Bit, big-endian signed integer, 2 channels, 48,000 kHz.
    I’m assuming I need a separate application to open these files and then convert to an Avid friendly format, but not sure what that app might be.
    If anyone has any ideas on how to deal with this footage, I would love to hear from you. Thanks!
    Dan Brother
    Ronn Kilby replied 14 years, 6 months ago 5 Members · 8 Replies
  • 8 Replies
  • Shane Ross
    March 16, 2012 at 6:32 pm
    YOu need to use AMA to access this footage. This is XDCAM EX footage. For that you need to install the XDCAM AMA plugin:
    https://avid.custkb.com/avid/app/selfservice/search.jsp?DocId=394827
    That link also has workflow guides for XDCAM.
    Shane
    Little Frog Post
  • Dan Brother
    March 16, 2012 at 8:53 pm
    Thanks Shane. I wasn’t aware this was XDCam footage since it wasn’t shot on an XDCam camera. I guess it’s a Sony thing.
    I appreciate your help!!
    Dan
  • Shane Ross
    March 16, 2012 at 8:55 pm
    What was it shot on? SxS cards are used in XDCAM EX cameras. I don’t know of another camera that shoots to that type of card.
    Shane
    Little Frog Post
  • Michael Hancock
    March 16, 2012 at 8:59 pm
    [Shane Ross] “I don’t know of another camera that shoots to that type of card.”
    The Alexa records to SxS, and it looks like JVC has an adapter that records .mp4 files to it:
    https://pro.jvc.com/prof/attributes/features.jsp?model_id=MDL101824
    Perhaps this is where the footage came from? I’m not sure if Avid has an AMA for it, though. Can you do a straight import? Is the SxS card recognized by your computer?
    Michael Hancock
    Editor
  • Dan Brother
    March 17, 2012 at 12:55 am
    It was shot on a Sony F3.
  • Juan Salvo
    March 17, 2012 at 4:37 am
    Yep. The F3 records in the XDCAM EX format on SxS cards. You do need that AMA plugin and all should work. If you haven’t figured that out already.
  • Ronn Kilby
    March 20, 2012 at 3:59 pm
    If you still have the files in a BPAV folder, you can also use Sony Clip Browser to export the file to mxf and use AMA with those files, or import those into MC. Actually even if they’re orphaned files you can still rebuild the BPAV folders (do a search for the procedure).
  • Ronn Kilby
    March 20, 2012 at 5:16 pm
    This from Chepal in Germany, regarding rebuilding BPAV folder structure from orphaned files:
    in clip_browser
    _file_import_choose your mp4s and they will appear in the top left window
    _in the bottom left window direct to the area you want to be in and create a new folder_select it
    _drag your mp4s from the top window to the bottom
    _look at the folder on your hard drive and you would find it has created
    new folder_BPAV_and all the stuff it needs.
