Activity Forums Adobe After Effects Sword Swipe effect
  • Tudor “ted” jelescu
    April 22, 2016 at 10:13 am
    Your example is classic animation – several drawings of the sword and swipe, a couple of frames of each most likely with a crossfade in between.
    That being said you could animate shape layers, have particle “light streaks” using Particular, or use the time effects and motion blur.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Jason Jantzen
    April 22, 2016 at 4:36 pm
    Could also try the “Echo” effect with some creative tweaking. I’ve used that several times to get a “swipe” look on motion.
    Jason Jantzen
    vimeo.com/jasonj
