Activity › Forums › DaVinci Resolve › switching wave between davinci and color
  • switching wave between davinci and color
    Posted by Blase Theodore on December 14, 2010 at 3:28 pm
    It seems that Davinci is tying up the wave, and Color can’t access it anymore. Anyone know a way to be able to switch between apps, without having to launch davinci, uncheck wave support, and close?
    Christopher Adams replied 15 years, 9 months ago 7 Members · 12 Replies
  • 12 Replies
  • Christopher Tay
    December 14, 2010 at 3:34 pm
    Reseat the USB cable at the Wave panel end ?
    -chrispy
  • Sascha Haber
    December 14, 2010 at 5:56 pm
    Try to open the setup dialog an color and delink the Wave there
    A slice of color…
    DaVinci 7.0.3
    Dual Xeon 2,4
    OSX 10.6.5RAM 6 GB
    RAID 8TB intern
    Extern 6TB
    GTX 285 / GT 120
    WAVE
  • Joshua Helling
    December 14, 2010 at 7:23 pm
    If none of that works. Go into the Resolve software preferences and change the panel type to something other than Tangent Wave Devices. So I would check none.
    This might stop the Resolve software from bogarting the wave panels. Of course you’d have to set those settings back to use them within Resolve again.
    Sincerely,
    Joshua
    Director of Support
    Blackmagic Design Inc.
  • Vladimir Kucherov
    December 14, 2010 at 7:27 pm
    This last method is the one that seems to work best. It seems that Resolve’s Wave driver is running regardless of the application – even with Resolve quit the interface buttons all still work.
    When you launch color on top of that, things can get goofy. It’s of course annoying to have to launch Resolve, set the setting, and quit. Good thing Resolve starts up so quickly!
  • Joshua Helling
    December 14, 2010 at 7:53 pm
    Yeah, I think that is because we didn’t use the native Tangent software interface to integrate the Wave panel. I am relatively certain we are using our own Deamon.
    Basically if Resolve is setup to use the Wave Panel then it starts in that mode when you start the computer. If you change the setting to “none” then it doesn’t start this and the Wave can be utilized by other software.
    As to technically why we do it this way, I am not 100% sure but I think that it might have some performance benefit over using a typical HID interface. But again…not 100% sure of that.
    Sincerely,
    Joshua
    Director of Support
  • Vladimir Kucherov
    December 14, 2010 at 11:01 pm
    Actually that’s an interesting insight – but doesn’t it mean since you guys bypassed Tangent’s software, the chances of us getting a proper mappable client from them (like they have for Color) are slim?
  • Sascha Haber
    December 15, 2010 at 10:56 am
    I really second that request for a mapable client too.
    And I wonder why it is quite sluggish in Resolve compared to Scratch or Color.
    A slice of color…
    DaVinci 7.0.3
    Dual Xeon 2,4
    OSX 10.6.5RAM 6 GB
    RAID 8TB intern
    Extern 6TB
    GTX 285 / GT 120
    WAVE
  • Joshua Helling
    December 15, 2010 at 6:23 pm
    No…I don’t think that getting a mappable client would be slim. But that would have to be done by Tangent (I believe). And as for it being sluggish in comparison to the Color/Wave combo, I wouldn’t expect it to be.
    Though to be honest I haven’t tried them side by side. I will try to check into that a bit.
    Sincerely,
    Joshua
    Director of Support
  • Joseph Mastantuono
    December 16, 2010 at 4:23 pm
    Just go into Activity Monitor and quit the TangentPanelDaemon process.
    Color will then see the panel.
    You will have to re-boot to get the Panel to work in DaVinci again, but usually I don’t have to switch between the two more than once a day so it’s not a big deal.
    Joseph Mastantuono
    Online Editor – Colorist – Post Consultant
    917.969.1583
  • Blase Theodore
    December 16, 2010 at 4:48 pm
    Excellent. Thanks Joseph, thats the kind of solution I was hoping for, thanks!
