Activity Forums VEGAS Pro Switching to Vegas after a background in Final Cut. A few questions.
  • Switching to Vegas after a background in Final Cut. A few questions.
    Posted by Brett Simon on September 5, 2010 at 1:25 am
    Hey guys. I’m pretty proficient in Final Cut since that’s what we used at my college but I’ve been away from an Apple for a long time and I decided I really need to get back to work and get on the workforce so I got Sony Vegas Pro 9 since that’s supposed to be the best.
    I’m not sure I like it.
    First thing I notice is that pressing space takes me back to where I first started playing it, rather than pausing there. Also, navigating around the timeline is annoying as hell because I seemingly can’t drag the pointer around as that just selects the piece. Is there any way to change the settings to what I’m used to with Final Cut?
    The other thing is that my video previews I’m dealing with are extremely laggy. The ones I have from my actual camera run fine, but the ones from my Droid X — which are in 3gpp format — absolutely do not want to run. Even turning the preview to draft settings turns the picture to garbage yet doesn’t fix the running. Audio plays fine. I’m thinking it’s just a format problem, that the program doesn’t like it, so what can I export it as without losing any quality? Likewise, what export settings (or render, whatever) do you prefer?
    Thanks in advance for any advice you can give me!
    John Rofrano replied 16 years ago 3 Members · 2 Replies
  • Drew Tanner
    September 5, 2010 at 7:08 am
    Hey, I have a background in Final Cut Pro and Vegas too (although version 8). I actually went the opposite way as you did, starting in vegas.
    The spacebar thing can be changed in the options, but you can also use ENTER, which will start/pause the video at its current location.
    As for navigation, you can drag the timeline from the timecode strip at the top. Mousewheel scrolling + SHIFT does the same thing. Mousewheel + CTRL moves the timeline up and down (if you’re dealing with a lot of tracks).
    And finally, if the playback is choppy you can try setting a lower quality on the preview window (above it in the drop down list). Or you can select an area of timeline and use SHIFT + B to do a quick render to memory. This is a kickass feature if you have a lot of tracks/compositing and want to see it play back smoothly.
    As for the phone video, I don’t know. I suppose you could always use something like virtualdub to export it. Hopefully somebody more knowledgeable about formats can help you.
    Vegas is great once you learn its little quirks. Btw, speaking of quirks, if you have trouble pinpointing a place in the timeline to edit: CTRL/SHIFT + click on the event. This always annoyed me until I figured it out. Because sometimes you want to highlight the track to cut and the cursor moves slightly when you click. This always annoyed me until I figured it out. good luck 🙂
  • John Rofrano
    September 5, 2010 at 11:35 am
    As Drew said, you can change it. Use Options | Preferences | General and down by the bottom of this list check Make spacebar and F12 Play/Pause instead of Play/Stop
    If you hover your mouse over the ruler at the top of the track area it will change to a hand. This indicates that you can drag the ruler to scroll the track area back and forth. You can, of course, use the scroll bars at the bottom and the sides. Double-click the bottom scroll bar to toggle between the entire project view and normal view. Double-click the vertical scroll bars to toggle the track height from minimized to normal height. Finally, you can scrub the timeline by dragging the top of the Timeline Cursor sometimes referred to in other NLE’s as the Current Time Indicator (CTI).
    FCP would have you transcode everything that you edit into Apples ProRes422 format. Vegas lets you edit native formats but sometimes this doesn’t perform well. In those cases it’s best to transcode these to another format as Drew said. Cineform is the digital intermediary of choice on the PC. It is visually lossless. You can buy it for $99 USD (Cineform NeoScene) at Videoguys.com. M-JPEG works great for SD and HD but is more lossy.
    ~jr
    http://www.johnrofrano.com
    http://www.vasst.com
