Activity Forums Apple Final Cut Pro Legacy Switching through multiple camera angles
  • Switching through multiple camera angles
    Posted by Joseph Nibbs on August 3, 2010 at 11:10 am
    I am recording concerts of my band and have two camera angles. in the edits i would like to be able to have the Music playing and then switch from one camera angle to the other seamlessly and sometimes with transitions . How do I go about doing this?
    I would like to be able to switch back and forth several times during each song, We are playing jazz and the focus keeps changing from one musician to the other.
    Simon Hustings replied 16 years ago 2 Members · 1 Reply
  • Simon Hustings
    August 3, 2010 at 2:03 pm
    Hi Joseph,
    Would probably suggest doing a multiclip edit. Sync both angles via timecode or in-point, select your audio source from either camera angle then start cutting. When your done with the cut, collapse the multiclip sequence and add the required transitions. Check out the FCP Manual for multiclip editing. You can’t go wrong!
    All the best,
    Simon
    “Is it me or do I spend half my life watching little grey bars turn into little blue bars??”
