Activity Forums Apple Final Cut Pro Legacy Switching Source Media to Reference-Movie by Relinking
  • Switching Source Media to Reference-Movie by Relinking
    Posted by Peter Egermann on March 23, 2009 at 12:45 pm
    I wondered why this doesn’t work: I am using ProRes422 media in an FCP project. I made some changes to the source media, exported it as a reference movie in FCP, and tried to relink from the self-contained original to the new reference movie. But FCP states that the media i try to relink to has different start and end points (the length of the two movies is exactly the same) and that the tape isn’t the same. Why is that? And is there a workaround or something? Is it possible to force FCP to relink?
    Thanks for any advice,
    Peter
    Peter Egermann replied 17 years, 5 months ago 2 Members · 2 Replies
  • Kevin Monahan
    March 23, 2009 at 7:22 pm
  • Peter Egermann
    March 23, 2009 at 8:01 pm
    Hi Kevin,
    I did not make any speed changes, but your question made me check the length again and I found the solution for my problem: The length of both clips was the same but since I imported the media in FCP and exported it from there, the timecode changed. The reference movie started at 01:00:00:00 (according to the FCP default). Setting this to 00:00:00:00 and exporting it again solved the issue.
    Thanks a lot,
    Peter
