Activity Forums Adobe After Effects switching out a color across an entire project
  • switching out a color across an entire project
    Posted by Christy Pessagno on August 20, 2011 at 5:52 pm
    i have a motion graphics project that uses only 3 colors. right now they are white, black and orange. i want to make all of the whites turn to a cream color and all of the blacks to turn to a dark grey color.
    does anyone know if there’s a way to do this across the board, or do i have to go through the project and change each element individually?
    thanks for any suggestions/answers in advance!
    Editor :: Videographer :: Photographer
    Walter Soyka replied 15 years ago 4 Members · 3 Replies
  • Ben G unguren
    August 20, 2011 at 7:28 pm
    It depends on how things are set up. If your 3 colors are coming from 3 colored solids then you can change the color of one solid (in the solid settings — cmd+shift+Y / ctrl+shift+Y) and make sure that it is affecting ALL instances of the solid (note the checkbox at the bottom of your solid settings).
    If you’re using another method for the color, like the Fill effect, then you could link them all to three master controllers using expressions…. That would take a little while to set up, but once it’s set up you can make lots of changes quickly.
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Todd Kopriva
    August 20, 2011 at 10:45 pm
    Ben’s suggestion is the right way to do this from the beginning, but a quick and dirty way to do this after the fact is to use a few instances of the Change To Color effect.
    Technical Support for professional video software
    After Effects Help & Support
    Premiere Pro Help & Support
  • Walter Soyka
    August 22, 2011 at 1:03 am
    I’ve just written a feature request [link] asking for project-level color swatches. If this sounds like an important feature to you too, I’d ask that you submit a similar feature request, too.
    Walter Soyka
