Activity Forums Adobe After Effects Expressions Switching Opacity inside the same comp
  • Switching Opacity inside the same comp
    Posted by Marcelo Cabral on September 26, 2017 at 7:16 pm
    HI
    I have a composition with several images. A slider control located in an external composition allow showing one of those images by switching the opacity of the image layers. What I need is add the opacity switching control inside of the composition of the images not outside.
    I need to add an Adjustment layer inside the image composition to make them independents.
    Thank you in advance.
    This is the current expression code which I need to modify
    C = comp("Scene 01");
    ctrl = C.layer("CONTROL").effect("SHOW")("Slider");
    L = C.layer(thisComp.name);
    val = Math.round(ctrl.valueAtTime(time+L.startTime));
    if (val == index) 100 else 0
    Marcelo Cabral replied 8 years, 11 months ago 2 Members · 5 Replies
  • Dan Ebberts
    September 26, 2017 at 7:43 pm
    Something like this should do it:
    s = thisComp.layer(“CONTROL”).effect(“SHOW”)(“Slider”).value;
    if (Math.round(s) == index) 100 else 0
    Dan
  • Marcelo Cabral
    September 26, 2017 at 7:50 pm
    It works perfectly!!
    Thank you, Dan.
  • Marcelo Cabral
    September 27, 2017 at 1:57 pm
    Hi Dan, me again.
    The expression to switch the opacity of the layers works perfectly inside the same composition. The thing is I need to set up 3 different sets of images and I have tried to do it in lots of ways using the same expression but it doesn’t work.
    This one works well for the first set of images but as soon I add more images as a different set with a different slider, even in a different adjustment layer, only one set works. I need to add at least three image sets inside the same composition. Thank you in advance for your help Dan.
    Cheers.
    s = thisComp.layer("EMOJI 01").effect("EMOJI_02")("Slider").value;
  • Dan Ebberts
    September 27, 2017 at 3:41 pm
    It should work if you set the slider to 18 for the start of the second group. If you want the indexing to start over with each group, you need to do something like this:
    s = thisComp.layer(“EMOJI 01”).effect(“EMOJI_02”)(“Slider”).value;
    firstLayer = thisComp.layer(“Layer 72”);
    if (Math.round(s) == (index-firstLayer.index+1) 100 else 0
    Dan
  • Marcelo Cabral
    September 27, 2017 at 6:43 pm
    Hi Dan
    It works perfectly!! I have now three groups and I have adjusted each slider from 0 to 50 and they work fine.
    Amazing support man. As we usually said in Argentina “El que sabe, sabe.” (who knows, really knows.!)
    Thank you!!
    Marcelo
