Activity Forums Compression Techniques switching fields
  • switching fields
    Posted by Bill Macomber on October 23, 2008 at 10:51 pm
    Hi, guys!
    I have a client that needs me to deliver MPEG-2 program streams for use in a Grass Valley Turbo system.
    Everything is dialed in except for one major problem: I’m coming from DV (lower field dominant) and going to their upper field dominant specs.
    Can anybody suggest a workflow that will not give me jittery-frame playback issues? How can I switch the field dominance correctly?
    Currently, I come out of Final Cut Pro 6.04 and use Compressor to encode the MPEG-2 file. I am using Compressor to set the field dominance to upper, setting it in the inspector at the encoder menu>video format>field dominance>upper.
    Bill
    Daniel Low replied 17 years, 10 months ago 2 Members · 1 Reply
  • Daniel Low
    October 23, 2008 at 11:35 pm
    Have you tried switching it in the FCP browser?
    Please post back saying what solved your problem. It could help others, and saying ‘thanks’ is free!
