Activity › Forums › Adobe After Effects › Switching between Alpa/Alpha Inverted with checkbox
  • Switching between Alpa/Alpha Inverted with checkbox
    Posted by Igor Stikic on December 19, 2012 at 11:21 am
    I want to control with Main comp/Null layer (checkbox) other Comps layers Alpha matte (8 comp/8 layers}. If is Check to be Alpha, and if is unCheck to be Alpha inverted.
    Is it possible?
    Thanx in advance
    Igor Stikic
    Igor Stikic replied 13 years, 9 months ago 3 Members · 3 Replies
  • Tudor “ted” jelescu
    December 19, 2012 at 12:13 pm
    Not exactly- at least I do not now how to do it the way you describe, but here’s an alternative:
    Add a Expression Control/SliderControl to your Null layer and lock the Effect Control panel. Open your Precomp and add Effect/Channel/Invert to the layer with Alpha. Link the “Blend With Original” control with the Slider Control. Now you can control the Alpha – at 100% you will get the layers alpha and at 0% the inverted alpha.
    Hope this helps.
    Tudor “Ted” Jelescu
    Senior VFX Artist
  • Vishesh Arora
    December 19, 2012 at 12:32 pm
    Igor
    You can use Set Matte Effect for this function.
    Instead of track matte, use set matte effect for each layer and then parent the Invert Matte checkbox to a controller’s Checkbox.
    Here is an example:
    5103_setmatteeffectwithcheckboxcontroler.zip
    But I would suggest you to read about Set Matte Effect first.
    Vishesh Arora
    3D and Motion Graphics Artist
    Films Rajendra
    Blog:
    https://digieffects.wordpress.com
    Demo Reel(3D):
    https://www.youtube.com/watch?v=lHPgIJU_BR8
  • Igor Stikic
    December 19, 2012 at 12:36 pm
    Thank you, this helps!
    Igor Stikic
