Activity › Forums › Adobe Premiere Pro › Switcher. I need Control Surface for mixing
Posted by Jose Lomeña on June 27, 2011 at 8:01 amHi, any way to mix audio with a control surface?. Any pluging or something?
I want to leave fcp and switch to premiere, i only need this to change.
Jose
Gus Evangelista replied 15 years, 2 months ago 4 Members · 3 Replies -
David Cherniack
June 27, 2011 at 9:44 amRight now the only way that you can employ a control surface in mixing is to OMF output to a DAW that supports it.
David
AllinOneFilms.com -
Tom Daigon
June 27, 2011 at 4:10 pmI put in a feature request yesterday for the Tascam FW-1082 control surface. Adobe is very response to customer desires. Make your feature request here…
https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
Tom Daigon
Avid DS / FCP / After Effects Editor
http://www.hdshotsandcuts.com -
Gus Evangelista
June 30, 2011 at 1:57 amAdobe Audition has surface control and round-trips with PPro, and part of the Production Suite.
“Adobe (Audition) has only programmed there software to work with the Mackie Control protocol”
I, too would like to have ( and have wanted for a while) Control Surface capabilities in PPro.
Theoretically, they will only put it in if it is requested enough times to rank high enough in the ‘priority’ list. That said, I foresee a whole bunch of FCP-like functions in the near future, finally.
Hope this helps.
Pr Ae Ps Il … and former FCP
