Activity Forums Adobe After Effects Expressions Switch parent layer using Checkbox
  • Switch parent layer using Checkbox
    Posted by Stephan Zammit on April 25, 2018 at 8:27 am
    Hi, I am currently working on a rig. During animation I wanted to give the option to switch the parent of a number of layers to become parented to another layer, using a checkbox. So basically when checkbox is on they are parented to layer 01, then when checkbox is off they are parented to layer 02. Is this possible, or do you know a way to turn around this. Even maybe a way without parenting.
    I was trying to constraint position & rotation directly to layer 01, then when checkbox is off switch the constraint to the position & rotation of layer 2; but this makes the layer jump to the other layers position. I would like it to maintain its current position and rotation and just follow layer 2 as in parenting.
    Kalleheikki Kannisto replied 8 years, 4 months ago 2 Members · 1 Reply
  • Kalleheikki Kannisto
    April 29, 2018 at 8:01 am
    I’d say it is doable, but you will save time and pain by splitting the layer(s) at the hand-off point and using a different parent for the two parts of the split layer(s).
    Although I haven’t tried it, were you to do this with a checkbox plus expressions, it seems that you would have to subtract the position of the first layer at the time (valueAtTime) when the checkbox is ticked/unticked and “parent” to the second layer by expressions, not by pick-whipping. Not too straightforward, IMO.
    Senior Graphic Designer
