Activity Forums Adobe Premiere Pro Switch from widescreen to standard
  • Switch from widescreen to standard
    Posted by Lumpynifkin on October 15, 2007 at 7:48 pm
    Hey guys,
    I created a project in wide screen mode(selected when creating a new project). Now i want the same exact movie but in standard setting. I just want to cut off the extra space on the side not shrink it or disproportion it. I created a new standard project then imported the wide screen project into the standard one. When i watch the movie in the monitor it plays exactly how i want it. But when i export the movie, i get a squished movie. Whats going on??
    Thanks for any help, any more info needed just let me know.
    Blast1 replied 18 years, 11 months ago 3 Members · 9 Replies
  • 9 Replies
  • Blast1
    October 15, 2007 at 8:12 pm
    Horizontal Pixel aspect ratio, its 1.2 for WS .09 for Standard
  • Lumpynifkin
    October 15, 2007 at 8:52 pm
    Changing this does not help. For some reason black bars are being added to the sides of my footage. I can’t get rid of them. I captured in wide screen, then imported the wide screen project into a standard def project. but its still exporting a wide screen version. Even if i set the pixel ratio to .9.
    Please don’t tell me i have to re-import and re-edit the entire video
  • Blast1
    October 15, 2007 at 9:08 pm
    When you say you captured in widescreen, what camcorder did you capture from?
    Also when you say you have black bars on the sides is that in widescreen or standard?
  • Lumpynifkin
    October 16, 2007 at 1:19 am
    I captured standard video, if i open just the video file its standard. the black bars are in both wide screen and and standard
  • Blast1
    October 16, 2007 at 3:16 am
    [lumpynifkin] “I captured standard video,”
    From what?
  • Mike Velte
    October 16, 2007 at 10:32 am
    Import your WS footage into a standard DV project. Use the motion control to stretch the footage on the X axis by about 25%. Then just pan with the motion control to keep interesting stuff on the screen.
  • Lumpynifkin
    October 16, 2007 at 1:47 pm
    thats the problem I’m having is that it looks exactly how i want it in play back(on the monitor in Premiere) but only when i export do i get the black bars on the side.
  • Lumpynifkin
    October 16, 2007 at 1:49 pm
    I captured from a cannon video camera. If i open up the video that i captured separate from premiere it looks fine and is in standard proportion.
  • Blast1
    October 16, 2007 at 5:35 pm
    The reason I’m asking what camcorder model you are capturing from is to determine what you are getting for footage, If you have black bars on the sides of a wS project and you captured as WS you may have letterboxed 4:3 footage The workflow will determine whats happening, you should have said from the start: “I am capturing WS footage from a CANONxxxxxx that was shot on a XXXXxxxx to a project using a NTSC Widescreen preset, then describe how you are exporting it, settings, etc.
