Activity Forums Adobe After Effects Expressions Switch Case in text layer returns the switch the value, Having to use switch(true)
  • Switch Case in text layer returns the switch the value, Having to use switch(true)
    Posted by Frederic Antoinette on August 28, 2018 at 7:33 am
    Created a pseudo effect for a template, with a popup.
    And depending on the what is on the popup the sentence should change.
    here is the code
    sel = thisComp.layer("Control").effect("Carry Forward")("First Message");
    switch(sel){
    case 1:
    "CARRY FORWARD PICK 6" ;
    break;
    case 2:
    "CARRY FORWARD PICK 8";
    break;
    case 3:
    "CARRY FORWARD PICK 4";
    break;
    However though it doesn’t give me any error it ends up with the text displaying the “sel” value.
    That is “1”, “2”, or “3” instead of the sentence.
    I also tried to put
    value = “….” in the cases
    same results
    Searching the web I saw something about a switch using “true” instead of a variable, this one worked:
    switch(true){
    case (sel ==1):
    break;
    case (sel == 2):
    break;
    case (sel == 3):
    break;
    Any idea why the first one didn’t work, shouldn’t it have the same results?
    Frederic Antoinette replied 8 years ago 2 Members · 2 Replies
  • Andreas Brand
    August 28, 2018 at 8:44 am
    I tried it with a slider control and it didn’t worked out until I rounded the number.
    Maybe this will help your problem too.
    sel = Math.floor(thisComp.layer("Control").effect("Carry Forward")("First Message"));
    switch(sel){
    case 1:
    break;
    case 2:
    break;
    case 3:
    break;
  • Frederic Antoinette
    August 29, 2018 at 6:37 am
    Good catch.
    It worked
    I would have done that if I was using a slider, but I though with a pseudo popup it wouldn’t be needed.
    So I guess I will call it a little bug that the value of these pseudo popup effects are not exact integers and we need to round it.
