Activity Forums Adobe After Effects switch a composition from rate back from 29.96 fps to 25fps
  • switch a composition from rate back from 29.96 fps to 25fps
    Posted by Jean Mathis on October 25, 2011 at 3:50 am
    I just finished an animation the first part of it (its not totally finished yet)
    I misunderstood my clients terms: he wanted a 25 fps comp
    and I did everything in 29.96, of course when switch the comp back from 29.96 to 25 fps all keyframes
    are not adjusted on the 25 fps. Is there a way to get this straight without doing the whole animation
    again from scratch in a 25 fps comp?
    Thanks guys…
    Jean
    Jean Mathis replied 14 years, 10 months ago 3 Members · 6 Replies
  • Ben G unguren
    October 25, 2011 at 7:57 am
    If there isn’t any footage, you can probably just get away with nesting your 29.97 comp in a 25fps comp. Heck, even if you have footage it might work.
    The main problem with this approach is when you have precise masking going on (like for rotoscoping) — on certain frames AE will choose a value that is between two of your keyframes (since the frames from a 29.97 comp won’t line up precisely with a 25fps comp, likewise with keyframes), and that can cause troubles. But that’s certainly the easiest way to do it IMO: Nest, change frame rate, render. Check for errors.
    Ben Unguren
    Motion Graphics & Editing
    http://www.mostlydocumentary.com
    This happens because the functionality/content marked as “Vimeo framework” uses cookies that you choosed to keep disabled. In order to view this content or use this functionality, please enable cookies: click here to open your cookie preferences.
  • Jean Mathis
    October 25, 2011 at 9:01 am
    ok will try this thxs
  • Roland R. kahlenberg
    October 25, 2011 at 10:23 am
    There’s a link to an updated script on the following link that should do the trick – https://www.aenhancers.com/viewtopic.php?f=3&t=873&hilit=keyframe
    HTH
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia.
  • Jean Mathis
    October 25, 2011 at 10:47 am
    Thanks Maestro!
    Jean
    October 25, 2011 at 12:08 pm
    You’re most welcome Mr ZANG! Do let us know how the script works out.
    Cheers
    RoRK
    Intensive AE & Mocha Training in Singapore and Malaysia – Adobe ACE/ACI (version 7) & Mocha Approved Trainer – Imagineer Systems Inc
  • Jean Mathis
    October 26, 2011 at 8:47 am
    Worked like a charm. Saved me a lot of trouble.
    Infinite thanks.
    Jean
