Activity › Forums › Adobe After Effects › Swirling Christmas Tree
Posted by Scott Moore on November 3, 2011 at 9:32 pmI am looking to recreate this swirling Christmas tree.
It has a ribbon and particles.
My questions is how do you do this in After Effects and AE only?
Scott
Michael Szalapski replied 14 years, 11 months ago 2 Members · 4 Replies -
Michael Szalapski
November 4, 2011 at 1:53 pmI can’t see your example video, due to restrictions on the network where I work, but here’s a start: [link]
– The Great Szalam
(The ‘Great’ stands for ‘Not So Great, in fact, Extremely Humble’)No trees were harmed in the creation of this message, but several thousand electrons were mildly inconvenienced.
Scott Moore
November 4, 2011 at 2:00 pmThanks but that isn’t quite the same effect.
See if you can see this link.https://wolocreative.com/display_video.php?id=222
its more of a path in 3D.
Scott
Michael Szalapski
November 4, 2011 at 2:21 pmOh. That should be fairly easy to do. Just create an animation on your emitter and set the particles to have a no velocity.
One way to get the swirly animation, would be to parent a light to a null object and move the light closer to the null object as the null rotates around its y axis and moves upwards. Then have Particular follow the light with the emitter.As far as the ribbon goes, it’s just an image of a ribbon (you could make it in Photoshop fairly easily) being revealed with a stroke (follow any write on tutorial).
– The Great Szalam
Michael Szalapski
November 4, 2011 at 2:23 pmAlthough, now that I look at it, they didn’t even go that far. That’s not in 3d at all. You could do this with any particle system in 2d. Just make the emitter follow the swirl shape.
– The Great Szalam
