Activity Forums Apple Final Cut Pro Legacy swf files into FCP
  • swf files into FCP
    Posted by Matthew Kasey on January 12, 2007 at 4:53 am
    I need to get some flash animations into FCP, but they’re in a swf file format, and I can’t figure out how to turn them into anything else. Is there some program or something I can use to convert it to a quicktime or something else useful?
    Pons Maar replied 19 years, 8 months ago 6 Members · 6 Replies
  • Bret Williams
    January 12, 2007 at 6:09 am
    Yes. Quicktime. Open them with QT and output them as a quicktime. Usually works, but I’ve had it not open. Probably due to version issues on one side or the other. Also, with SWF being interactive, you’ve got to realize it may not quite come out as you expected. If it’s just a play through anim, it should be ok.
  • Bret Williams
    January 12, 2007 at 6:24 am
    Nevermind. Doesn’t seem to work these days. A year ago I dd a large project which first consisted of adapting flash to QT. I simply used QT player.
    I guess you’ll have to use squeeze or flash.
  • Dit Ben
    January 12, 2007 at 1:17 pm
    You can convert to quicktime using ffmpeg (https://homepage.mac.com/major4/)
  • Stuart Simpson
    January 12, 2007 at 2:16 pm
    Might be worth trying Perian:
    https://perian.org/
    -Simmie
    2 G5 – Kona LH
    3 G4s – Cinewave
    1 xbox360, 1 PSP, 1 PS2 & a Gamecube
    https://www.speak.co.uk
  • David Bogie
    January 12, 2007 at 4:03 pm
    Open Flash and export them as QT to the Animation or DV codecs.
    If you don’t have Flash, find someone who does, like the guy who gave you the files.
    If you’re going to be doing this often, get Flash.
    I hate Flash.
    bogiesan
  • Pons Maar
    January 21, 2007 at 3:55 am
    A great little piece of software, costs $24 but you get to try it out for free:
    https://www.techspansion.com/visualhub/
