Activity › Forums › Adobe After Effects › SWF file too big
  • SWF file too big
    Posted by Tony Wanders on December 12, 2006 at 8:29 pm
    Hi Guys,
    This is my first post here and if this topic been discussed before i apologise. I have created a flash intro in adobe after using the 3d camera stuff. but the problem now is when I import it to flash the size is huge like 4 mb. The intro is like 20 seconds only and I never expected it to be so big. Is there anyway to compress the movie to around 1.5 MB like that? I am pretty new to after effects and not really sure about the what setting is the best for web stuff. Anyone who can help me I would really appreaciate it.
    Thank you
    Regards
    Tahsin
    Aharon Rabinowitz replied 19 years, 9 months ago 3 Members · 6 Replies
  • Aharon Rabinowitz
    December 12, 2006 at 10:22 pm
    Are you using the On2 VP6 codec? It’s good quality and usually smaller than the standard flash codec. VP6 comes with Flash 8.
    I generally use Sorenson Squeeze, a program for compressing video while keeping the quality good. It can compress video better than you host application (like Flash or After Effects) could ever do. And you can specify/constrain the size of th final file.
    https://www.sorensonmedia.com
    I’m no expert in flash by the way – you’re probably better off posting at the Cow Flash forum.
    Aharon Rabinowitz
    aharon(AT)yahoo(DOT)com
    http://www.allbetsareoff.com
    Creative Cow Master Series DVD
    particleIllusion Fusion Volume 1
    available @ http://www.pIllusionFusion.com
  • Tony Wanders
    December 13, 2006 at 12:06 am
    Hi Aharon,
    Thanks for your reply I am going to check out the site but its seems the server is busy but will check it out soon. I noticed a lot of professional business companies are using different software tools to create flash intros nowadays which is really great an example is
    https://www.chunkypig.com/templates/flash_intro_templates/business.php
    I guess most of them were done in after effects and bought back in flash. One of the reason why I want to learn after effects now.
    cheers
  • Mylenium
    December 13, 2006 at 9:27 am
    You should not use the SWF export in AE. It is based on the old Flash 5/6 formats and will more or less rasterize every frame and embed it as a JPEG or PNG. Like Aharon said, fopr more efficient compression create an FLV and import it into Flash.
    Mylenium
    [Pour Myl
  • Tony Wanders
    December 13, 2006 at 12:57 pm
    Hi Mylenium
    I just figured that out last night and it works great! from 4 mb its not 1 MB just nice I cant to finish my project soon.
    cheers
  • Aharon Rabinowitz
    December 13, 2006 at 1:42 pm
    It’s being exported from Camtasia Studio in flash 8 format.
    Aharon Rabinowitz
  • Aharon Rabinowitz
    December 13, 2006 at 2:38 pm
    wow. I toatally got my posts crossed here.
    I thought I was responding to the tutorial related flash post. Ignore the above… No more posting before breakfast…
    Aharon Rabinowitz
