Activity Forums Maxon Cinema 4D Sweeps NURBS Material Question
  • Sweeps NURBS Material Question
    Posted by Jason Connolly on July 1, 2005 at 12:21 am
    Hello the COW!
    So, I have a logo extruded with a sweep nurb along a spline(see here). I would like the face to be a different color than the extrusion. However, in order to do that, I make my Sweep NURB editable, and in turn, I lose the sweep NURB controls(Growth, Scale, Rotation).
    I’m sure this is easy but I can’t figure out how to maintain sweep NURB control and have more than one material applied to the logo.
    Any feedback welcome!
    Thanks!!
    Jason
    Huib J. lirb replied 21 years, 2 months ago 4 Members · 5 Replies
  • Joe Bird
    July 1, 2005 at 1:52 am
    Use the same controls as extrude: C1,(caps) R1 (bevel) in the selection line of the material tag.
  • Huib J. lirb
    July 4, 2005 at 7:25 am
    The sweep nurbs object does not appear to behave itself in the same way, though. I did not succeed in applying materials separately onto the C1 and R1 selections (the cap and bevel) of such an object whereas I did manage to do so with an extrude object (following the method indicated). Perhaps it’s not that simple, then?
  • Huib J. lirb
    July 4, 2005 at 10:17 am
    Oops. I have to correct myself: please ignore the previous post. The separate caps and bevel materials did not, at first, seem to show on the sweep nurbs because they were set at the wrong end. And that was the case because I thoughtlessly filled in “C1” and “R1” in the selection line of the material tag. After I changed that into “C2” and “R2”, however, I did get the desired result. So, in other words, “Bear” was right, but please make sure you check at the right end!
    P.S. Of course, you might also like to be able to separately colour the various strands or rows of the “sweeping sides” of the sweep nurbs object, but I have no idea how to do this without first making the object editable. For a playful loop involving sweep nurbs objects, see this movie. This only serves to illustrate the kind of sweep nurbs object I had in mind. (I am presently rendering a sketch & toon version with separate caps en bevel materials, but since my previous Sketch and Toon movies did not compress well into Mp4, I thought it best to just refer to this old movie with singular materials; I tend to post my WIP on my weblog at https://luepp.blogspot.com).
  • Ingemar Björling
    July 6, 2005 at 8:14 pm
    “P.S. Of course, you might also like to be able to separately colour the various strands or rows of the “sweeping sides” of the sweep nurbs object, but I have no idea how to do this without first making the object editable”
    Is this what you mean: https://www.renderwise.com/supportfiles.htm
  • Huib J. lirb
    July 11, 2005 at 2:28 pm
    I am sorry, but I cannot find your example at the linked location; you may have already removed it before I checked it out (since I have not visited the forum this weekend). So could you please “reload” your reference, so to speak?
