Activity Forums Maxon Cinema 4D Sweep Nurbs wont work with Ai Text?
  • Sweep Nurbs wont work with Ai Text?
    Posted by Adam Duguay on April 12, 2007 at 6:43 pm
    Hi all!
    I am trying to create some animated text with sweep nurbs, but my Illustrator 8 file wont work when I import it and drop it into the sweep Nurbs hiercy.
    In the extrude nurbs settings, there is a check box called “hierarchical” wich takes the parented splines from the illustrator file and allows you to create the text. Sweep nurbs
    does not have this hierarchical checkbox. I’ve tried creating a compound shape in Illustrator but it doesn’t seem to work. I might not be selecting the right compound in Illustrator though.
    Hope someone can help.
    A
    Brian Jones replied 19 years, 5 months ago 2 Members · 2 Replies
