Activity › Forums › Maxon Cinema 4D › Sweep NURBS growth w/ Tracer Object
  • Sweep NURBS growth w/ Tracer Object
    Posted by Corrado Carlevaro on June 5, 2014 at 6:18 pm
    Particles traced by Tracer Object, resulting splines in Sweep NURBS, so far so good. I want a first Sweep NURBS to be 100% length, and a second Sweep to be a kind of “coating”, thicker and shorter, as in picture.
    Growth parameter doesn’t work because it sees the splines as a single spline, and the Details/Scale curve works as a percentage.
    What I want is a fixed difference, as if the second Sweep NURBS would be delayed by some frames, would “start later”. Any advice? Xpresso perhaps?
    Thank you in advance
    Corrado
    Corrado Carlevaro replied 12 years, 3 months ago 2 Members · 2 Replies
  • Adam Trachtenberg
    June 5, 2014 at 9:18 pm
    Here’s a sample scene: 7585_strippedwiressweep.c4d.zip
    What I did was clone a null onto the particles and trace the clones. Then I baked the cloner with a cache tag and duplicated it. Then I offset the animation of the copied cloner using the offset parameter in the cache tag. Then I created a second tracer referencing the second cloner.
  • Corrado Carlevaro
    June 6, 2014 at 7:30 am
    So you actually had to bake, duplicate and offset time; but I didn’t think to the Cache tag.
    Thank you Adam
    C.
