Activity Forums Maxon Cinema 4D Sweep Nurbs cap material
  • Sweep Nurbs cap material
    Posted by Baard Kolstad on December 9, 2016 at 9:16 am
    I’m a beginner in Cinema 4D, so please keep any replies as detailed as possible.
    I have a spline with Sweep Nurbs using a ring with filet caps. What I’d like to do is apply a gradient material to this Sweep Nurbs that goes from the start to end seen from any angle. I also intend to animate the growth of it, so making it editable doesn’t seem like a good idea.
    I have managed to do these things, the only thing missing is that the material doesn’t apply to the caps. This is the initial result I’m getting:
    So I searched a bit and found that you could target the caps in the selection of the material. So I made one material for the start color and one for the end color, that gave me the result I wanted:
    The only issue is when I animate the growth, It doesn’t follow along:
    Of course I could keyframe the color of the material to match up, but there surely must be a better way of achieving this?
    Thanks in advance!
    Baard Kolstad replied 9 years, 9 months ago 1 Member · 0 Replies
  • 0 Replies
