Activity Forums Maxon Cinema 4D Sweep along a Spline
  • Sweep along a Spline
    Posted by Lars Wikstrom on September 18, 2007 at 10:28 pm
    Hi, when I try to use the Sweep function to make a hose the image is flat. I was hoping it was going to sweep a circle along the spline which it does, but it make the circle flat on the ground plane so it doesn’t look like a hose.
    What am I doing wrong?
    -Lars
    Lars Wikstrom replied 19 years ago 2 Members · 2 Replies
  • Adam Trachtenberg
    September 18, 2007 at 11:21 pm
    Sounds like you need to adjust the axis of your circle (profile) spline. The Z axis should be pointing out.
  • Lars Wikstrom
    September 19, 2007 at 7:38 am
    Thanks, I will give that a shot.
    -Lars
