Activity Forums Adobe After Effects Expressions Swarm expression to form text with circles
  • Swarm expression to form text with circles
    Posted by Mike Morris on July 15, 2009 at 4:05 pm
    Hello all.
    I have a question about how to create an expression to make this animation:
    https://www.morriscreate.com/xango_sample.mov
    act more like a “swarm” of floating bubbles. As it stands right now, I have painstakingly set the beginning and end position for each circle, then pulled a camera back through the field of circles.
    The problem is, I want it to be more organic. I want things to swirl, wiggle smoothly, etc, almost like a flock of birds, but still have it end with the “thrive” logo.
    Any recommendations?
    Sib Ntsib Dua
    Xeeb
    Filip Vandueren replied 17 years, 1 month ago 2 Members · 1 Reply
  • Filip Vandueren
    July 18, 2009 at 2:50 pm
    Well, if you’ve allready set everything up, just add wiggles to position and scale, and then decrease all wiggle-amplitudes by animating a linked slider.
    do a search for wiggle slider and you’ll find a ton of examples.
