Activity › Forums › Apple Final Cut Pro Legacy › Swapping videos
  • Swapping videos
    Posted by Sam` Hancocks on December 29, 2011 at 11:14 pm
    Hi
    I am currently editing a video on Final Cut Pro 7. I have finished the edit but have had issues because the source videos were divx. Ive now converted the source videos to mov but the project timeline is still set out with the original divx videos. Is there an easy way to swap the .divx videos in the timeline with the new .mov versions?
    Jeff Meyer replied 14 years, 9 months ago 3 Members · 2 Replies
  • Steve Eisen
    December 30, 2011 at 1:40 am
    Easy setup creates sequences settings for you. .MOV is just an extension. FCP likes codecs such as ProRes, DV. Codecs such as h.264 do not work well with FCP.
    Open your mov files in QuickTime and check out the codec. It’s located under format.
    Steve Eisen
    Eisen Video Productions
    Vice President
    Chicago Final Cut Pro Users Group
  • Jeff Meyer
    December 30, 2011 at 4:23 am
    Right-click on the files to be replaced and pick Reconnect Media. Select Locate and point the computer to the new Quicktime versions of the files.
