Activity Forums Adobe After Effects Swapping out footage
  • Swapping out footage
    Posted by Michael Tesh on July 26, 2007 at 2:11 pm
    Ok so I made and animation with a certain still image, I also used that same still image elsewhere in the timeline later on. Same asset used in two different places. How do I swap out that first instance of the still image and retain the animation that’s used on it, without affecting the second use of that same asset on the timeline?
    I hope this makes sense.
    Let me try explaining a different way:
    One image, used twice, want to swap out the first use of that image for completely different image without losing all the fancy animation I applied to it the first time.
    Is this possible?
    Michael Tesh replied 19 years, 1 month ago 2 Members · 2 Replies
  • Jeff Mcbride
    July 26, 2007 at 2:15 pm
    Highlight the file in the Comp window, then option-drag(Mac) or alt-drag (PC) the new file on top of the old file.
  • Michael Tesh
    July 26, 2007 at 2:38 pm
    Excellent info, thank you.
