Activity Forums Maxon Cinema 4D swapping objects in C4D r11
  • swapping objects in C4D r11
    Posted by Rob Birnholz on November 11, 2008 at 2:31 am
    Learning C4D after a lifetime in Electric Image. Switching apps is quite challenge!
    Anyway, I have hundreds of little cubes and pyramids (nurbs) scattered throughout a scene, and now I have to swap them out for a different shape with a different texture. In EI this was not so hard, but in C4D I can’t figure it out.
    Anyone know the secret?
    Rob Birnholz
    Absolute Motion Graphics, Inc.
    Longwood, FL
    http://www.absolutemotiongraphics.com
    Adam Trachtenberg replied 17 years, 10 months ago 2 Members · 1 Reply
  • Adam Trachtenberg
    November 11, 2008 at 5:04 am
    Unfortunately there’s no easy way to change out objects unless you’ve set the scene up with instances or xrefs from the beginning. The Functions>Transfer command should make it a little less painful. :/
    Materials, otoh, are pretty easy. Just multiselect all the texture tags that have the matieral you want changed and then drag the new material from the material manager into the texture tag’s “Material” box.
