Activity Forums Adobe Premiere Pro Swapping clips on the timeline shortcut?
  • Swapping clips on the timeline shortcut?
    Posted by Keith Moreau on February 2, 2011 at 6:44 pm
    I can do this in FCP, I can’t seem to figure out how to do this in PPro or if it’s possible, even after reading the docs and researching it a bit. wondering if it’s possible in Premiere Pro:
    I have 2 clips, clip A and B, one after the other in the timeline. I want to drag A to the end of B, and have B move before A, I want to ‘swap’ them. With a simple keystroke in FCP I can do that.
    As it is now I have need to drag the clips to another track to move them out of the way and then back down to the original track which is a lot of steps.
    Thanks much for any advice.
    Keith Moreau replied 14 years ago 8 Members · 13 Replies
  • 13 Replies
  • Alex Udell
    February 2, 2011 at 7:59 pm
    rearrange edit
    here:
    https://tinyurl(dot)com/4vpnc54
  • Ann Bens
    February 2, 2011 at 8:53 pm
    Select clip B and drag it to the beginning of clip A while holding shift+Alt.
    Alex: please do not use short urls. One has no idea where one is directed to. I certainly will not use/click on them.
  • Alex Udell
    February 2, 2011 at 9:39 pm
    Ann…
    the full url to the online help ket getting truncated because it was multiple lines long.
    Alex
  • Ann Bens
    February 2, 2011 at 11:10 pm
    Well, these short url’s can be very dangerous.
    Could you give me the title of the page, maybe i can get it to work.
  • Alex Udell
    February 3, 2011 at 2:37 am
    Home / Using Adobe Premiere Pro CS5 / Editing sequences and clips / Rearranging clips in a sequence
  • Ann Bens
    February 3, 2011 at 3:39 pm
  • Noam Osband
    October 4, 2011 at 6:17 am
    Keith, how do you do this move in FCP? I’m trying to do that now but cant figure it out.
  • Keith Moreau
    October 4, 2011 at 6:36 am
    I believe you start to drag the clip, then hold down the option key and the cursor turns into a curved arrow then place it before the clip you want to swap. I don’t use FCP that much so it might be control rather than option, give it a try.
  • Tom Simone
    November 25, 2011 at 4:43 pm
    I tried using shift-alt and drag, but this didn’t work for me. Instead, I found I can interchange two clips’ positions by holding cmd and dragging.
    I’m using a mac and the keyboard shortcuts are set to default.
    http://www.tomsimone.co.uk
    http://www.tomsimoneweddings.co.uk
  • Jon Barrie
    November 28, 2011 at 9:28 am
    swapping clips for PPro, Mac: hold cmd + alt, PC: hold ctrl + alt after dragging the clip and it will swap with the edit arrangement you drag it to.
    – JB
    Jon Barrie
    Adobe Video Solutions Consultant ANZ
    Jon’s YouTube Tutorial Page
    follow Jon with twitter
