Activity › Forums › Adobe After Effects › Swap Layer Source
Swap Layer Source
Posted by Jack Murphy on June 4, 2008 at 6:57 pmIf i already have a layer keyframed, and i want to duplicate that layer, and simply change the source footage, how do i swap the source image for another that already exist in the projects folder?
Steve Hix replied 8 years, 4 months ago 9 Members · 8 Replies -
Mike Clasby
June 4, 2008 at 8:16 pmYou can replace the footage in the project window with, Right-Click>Replace Footage>File.
Or maybe better is to swap-out a layer in a Comp, by selecting the layer to be replaced, then Alt-Dragging new footage from the project window onto the selected layer (oh, yeah, that new footage needs to already be in the project window for this one).
David Chang
April 2, 2010 at 6:45 pmGood question…!
Click the timeline object that you want to replace. Then alt-drag the new source from the assets window to the timeline.
God knows re-keyframing a new asset can be a huge pain.
Aza Allen
June 24, 2010 at 12:52 amAwesome, just the answer I was looking for as well…
Also, I have a timeline item that is key-framed and is the parent of other layers, when I try to alt drag a new item into it that’s a different size, it shifts everything (child layers and keyframes) over, and when I try to scale it down, all the child layers scale down with it… is there a way around this problem? ie to swap something in of a different size, but have it scale down automatically, or something?
Make sure to check out our website http://www.makeyourfriendsuncomfortable.com
Jordan Quackenbush
October 16, 2013 at 2:20 pmSo I know this is over 3 years, so apologies for resurrecting the dead. Just wanted to post in case someone else finds this via Google like I did.
In regards to Aza’s question, where if you have a smaller footage layer, such as a comp from iStock, and want to replace it in your final output after client approval, etc., then pre-comp your footage, leave attributes, and then replace it within the pre-comp. Scale it down there, etc., and then in your main comp it’ll be golden, barring any crazy pre-comping that’s already present – even then if you go to the base footage layer, you should be fine.
Andrea Bobick
February 25, 2014 at 7:26 pmFor some insane reason I never bothered to look this up and for years I’ve been doing a round about and terribly inefficient solution to this. Thank you!
Niels Albers
July 24, 2014 at 8:38 amAlso just found out by accident that this is possible via the shortcut..
Ctrl + Alt + /
Jamin Conn
September 10, 2014 at 10:34 pmyeah ctrl, option & / is one of my fav shortcuts.
so…
question for ya’all. Can I replace a text box from one comp into another without getting those ugly cut scars on my rists? I have 30 comps to update (standarizing title sizing) thought about writing an expression… sounds like a bad idea. so now I’m wanting to copy paste but parenting has to be re-connected, etc. problem being that text layers don’t exist in the project window.
-should i maybe pre-comp the title and then use the keyboard shortcut to replace? i think that might be my easiest option.
-Jamin
EnvisoonedStudios.com -
Steve Hix
May 9, 2018 at 2:56 pmGlad you did resurrect it, it helped me over four years later. No more re-keyframing!
